2000 Civic Idle Problem NEED HELP PLEASE!!!
Old 05-18-2005, 05:22 PM
civic919900's Avatar
Default 2000 Civic Idle Problem NEED HELP PLEASE!!!
I have a 2000 civic ex that iv been struggling with forever to get it to idle. Not long ago, i blew my stock motor up and the drag strip and then put in a 99 civic ex D16Y8 motor to replace the 2000 D16Y8. My old motor idled fine, only different things I did now is stage 1 clutch, lightweight flywheel, Headers, O2 sim, and Aem V2 intake. I replaced the IACV 2 times now. First with the one from my orginal motor and now a brand new one and still shitty idle. When coming to a stop the rpms will drop down to like 100-200 rpms, barly running. I need help!!!
Old 05-18-2005, 05:24 PM
Default Re: 2000 Civic Idle Problem NEED HELP PLEASE!!! (civic919900)
I NEED HELP!!!
Old 05-18-2005, 05:27 PM
stevenlo's Avatar
replace the thermowax valve or block it off and reroute the hoses!!!
the thermowax valve is the valve under the intake manifold
Old 05-18-2005, 07:03 PM
Default Re: (stevenlo)
Whats the function of the thermowax valve?
Old 05-18-2005, 07:05 PM
90civichb's Avatar
Default Re: (civic919900)
Why do you have an 02 sim installed? Are you getting any CELs? If so, post the codes so someone could possibly help you out more.
Old 05-18-2005, 07:09 PM
I have a high flow cat so i had to hook up the second o2 sensor so i didnt kick on the check engine light. before i installed I klept getting the IAC code, 02 sensor below threshold, and an EVAP leak code. Now I did the 02 sim and the brand new IAC tonight and cleared the codes out. So for after driving for about 2 hours and shutting the car of a couple times, the light hasnt came back on.
Old 05-24-2005, 06:08 PM
Old 05-24-2005, 07:11 PM
SOHCmaster's Avatar
Explain the thermalwax valve, I wanna hear more about this please..
Old 05-25-2005, 05:51 AM
EE_Chris's Avatar
Default Re: (PK SPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">Explain the thermalwax valve, I wanna hear more about this please..</TD></TR></TABLE>
It doesn't exist on a Y8.
The FITV is NOT present on all Civics and Integras.
SykoFerret
31
08-31-2012 05:51 PM
98sLicKvIc
07-05-2009 05:57 PM
importlover
09-27-2005 09:50 AM
dynamo
09-15-2005 11:38 PM
Quick Reply: 2000 Civic Idle Problem NEED HELP PLEASE!!!
