Removing fuel line help
Location: With my POS D15B2, Whereever whenever, United States
How do you remove the fuel line from the fuel filter
there seems to be a few screws that one overlaps the other
Re: Removing fuel line help (MugenHonda)
Which car?
On my 99 the top one is a 17mm wrench or socket and the bottom is a 14mm open-ended wrench, and I think a 17mm above that to hold the filter in place so the line doesn't bend.
Electrician
Remove the bolt from the top. It holds the banjo line to it. There's 2 washers in the assembly as well. Remove the bottom line with an open-end.
moonpieboy
10-09-2005 09:57 AM
