96 to 99 climate control conversion (no light!!!)
heres the deal. i converted my 96 climate control to 99. i replaced the following
the tube that connects the vents,
climate control,
si dash harness,
blower, heater, and all
but then when i turn on my lights the climate control doesnt light up but the cluster does, the radio does, and the emergency triangle does. the climate control blows when i turn it on and off and when i point to my feet face and such.. it also work for cold and hot. and the defrost a/c circulation led lights up. ive also tried three different climate controls and its all the same. ive also tried putting my climate control into another car to test it and it worked fine in the other car..checked the fuses.. unplugged the harnesses and replugged again but nothing..
my cousin did the same conversion 96 to 99 and he had no problems.. what could be my problem? any help will be appreciated!! thanks in advance
please dont tell me to search cause i wouldnt post this if i didnt find it.. unless i missed a thread that already covered this.. but thats less likely
climate control,
si dash harness,
Re: 96 to 99 climate control conversion (longbeachpurplecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longbeachpurplecivic »</TD></TR><TR><TD CLASS="quote">heres the deal. i converted my 96 climate control to 99. i replaced the following
climate control,
si dash harness,
climate control,
si dash harness,
climate control,
si dash harness,
climate control,
si dash harness,
HELP ME PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! and i found out my rear defrost doesnt work!!!!!!!!!
search rear def. you have to slice into the green plug that is not bein used i think its the blue yellow wire but search
Re: 96 to 99 climate control conversion (itr-00-436)
just to get more details i did a search on "rear defrost" as suggested (even though i didnt have to cause i already figured out my problem) for recent and there was none and i did on archives and had nothing to deal with my situation. so yea.
1 Post
Re: 96 to 99 climate control conversion (Crank)
I would say you have a bad wire or connection on the illumination wire. I have also done this conversion and there were no problems. Unfortunately I dont have a wire diagram so im not sure which wire you should check for power at this time but that would be where i woudl start.
heres my steps if you want to look through mabe youll see something. http://repo.jackmoves.com/album228
climate control,
si dash harness,
Therein may lie your problem. All you really needed was the 99-00 climate control wiring harness, not an entire dash harness.
climate control,
si dash harness,
xxjokoxx
07-15-2008 02:09 PM
