smoke at high RPM, bad oil? *searched
ok if i rev it or get it up to high RPMs (d16z6) i get some smoke out the exhaust.... i believe its a blu-blackish color (kinda like burned oil or something)
anyways, my oil is due for a change..so im gonna do the obvious and change it tomorrow, but if that doesn't help it...is there anything else it could be? from personal experience maybe? thanks
Re: smoke at high RPM, bad oil? *searched (mountaindewguy)
Rings....
How much smoke?? Ive seen quite a few Hondas smoke a tiny tiny bit up top when in Vtec.
Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">check your pvc valve
</TD></TR></TABLE>check your pcv valve.............thats what komat meant. we changed ours this weekend and they were both shitty. helps a lot.
peace
eric
peace
eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mountaindewguy »</TD></TR><TR><TD CLASS="quote">ok if i rev it or get it up to high RPMs (d16z6) i get some smoke out the exhaust.... i believe its a blu-blackish color (kinda like burned oil or something)
anyways, my oil is due for a change..so im gonna do the obvious and change it tomorrow, but if that doesn't help it...is there anything else it could be? from personal experience maybe? thanks</TD></TR></TABLE>
If the smoke is white/bluish, then that would be oil getting to the combustion chamber, through valves, valve seals or like piston rings.
If the smoke is black, then it is more fuel related. It means your are running rich in those rpm's.
Re: smoke at high RPM, bad oil? *searched (AdamQ3B85)
ive got a b16a2, and at top end mine blows a little smoke too..
i was tuned by Shawn Church last week, and around 8k id shoot out some smoke and lose about all my power.
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">.. do a compression check and come back to us and post the numbers..
How many miles does the engine have on it?</TD></TR></TABLE>
You actually can have good comp numbers and still burn oil...The top piston ring is what holds most compression in..The ring below that is what keeps the oil at bay...if this ring goes bad you can leak oil slowly.
Re: (citrus3000psi)
Hit your gas pedal go to about 7k rpm...release your gas pedal and kick it in...
if there is smoke it's youre valve seals...
if you have smoke when you are on the gas pedal i think it's youre piston rings
Re: (DutchEG6)
i just thought of something...not sure if it would make a difference or not....
those motors (z6) are built to take 87 unleaded octane.....since i've had it i've been fillin it with 89 w/ ethanol....just curious but could it be burning too hot or anything?
justa4banger
14
11-26-2008 04:39 PM
Spence
40
03-12-2007 09:51 PM
