Starting problems 92 cx
Old 05-19-2005, 02:54 AM
thaimonkey's Avatar
Default Starting problems 92 cx
i got this cx the otehr day and it runs. but when you first crank it up the first time of the day it takes awhile. you have to let it crank for about 7 seconds before it starts. once its starts and warms up starting it up again is no problem. i changed the cap and roor and put new plugs. still did no good. any advice?
Old 05-19-2005, 08:58 AM
thaimonkey's Avatar
Default Re: Starting problems 92 cx (thaimonkey)
damn, no one trying to help me out??
Old 05-19-2005, 09:06 AM
MidwestSi's Avatar
there is a TSB from honda on 92 civics for that same problem
Old 05-19-2005, 03:25 PM
thaimonkey's Avatar
Default Re: Starting problems 92 cx (MidwestSi)
where would i find out more info and the fix for it?. sorry im a noob. hahaha
Old 05-20-2005, 04:50 AM
MidwestSi's Avatar
call a honda dealership or in the haynes serivice manual for 92-95 SOHC in the first couple of pages there are symptoms and cranking before starting is one and there is a TSB doesnt tell you how to fix it but it has something to do with the fuel pump
Old 05-20-2005, 04:51 AM
thaimonkey's Avatar
so if i take it to a dealership they should fix it free right?.
Old 05-20-2005, 07:20 AM
Filthy Focker!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaimonkey &raquo;</TD></TR><TR><TD CLASS="quote">so if i take it to a dealership they should fix it free right?. </TD></TR></TABLE>
No... A TSB does not indicate a free of charge repair.
fs
Old 05-20-2005, 01:23 PM
thaimonkey's Avatar
Default Re: Starting problems 92 cx (filthy)
so does anyone know the exact problem?. help a noobie out.
Old 05-20-2005, 01:31 PM
Ignitecivic's Avatar
does it click click or is it just keeps on crankin and turning?
Old 05-20-2005, 01:33 PM
DeadVet's Avatar
Default Re: Starting problems 92 cx (Ignitecivic)
its the check valve in the fuel pump leaking. Happens to all civics at one time or another. You need a new fuel pump and 30 minutes of your time.
Old 05-23-2005, 02:54 AM
thaimonkey's Avatar
Default Re: Starting problems 92 cx (1TurboHatch)
ok thats too easy. it cranks and turns but doesnt start. like its not getting enough fuel. imma change the pump and see what happens there. thanks alot
pr3ylud3
05-23-2007 06:00 AM
1zach4
02-18-2007 11:40 AM
Lambo123
11
06-15-2004 10:59 AM
X CHB X
02-23-2004 11:35 AM
LisaCivic
31
05-21-2003 11:27 PM
Quick Reply: Starting problems 92 cx
