fuel gauge does not work
Re: fuel gauge does not work (doggworld1233)
what kind of car what kind of cluster? you can usually get that seperate fromt the cluster check slhonda.com and go though the parts and u will be set. i had to do this to my 99 si cluster i got. good luck
Re: (kleanlscivic)
if its manual part number is 78130-SR3-A22 showing price of 86.08
if its auto part number is 78130-SR3-A32 same price as above might be cheaper to find a used cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 »</TD></TR><TR><TD CLASS="quote"> my fuel guage does not work it is stuck on "F". how can i fix this with out buying a new cluster?
justin </TD></TR></TABLE>
did you mess with the cluster recently?
It's one a few things:
- You messed with the clusters and put the wrong screws back into the fuel gage and it is not making propper connections - hence reading full.
- check the fuel gauge send unit by the gas tank. disconnect it. if it drops, the problem might be there.
Re: fuel gauge does not work (Vero)
a friend of mine changed it over from a auto to a manual but it worked fine. where is the sensor you are talking about?
justin
justin
Voodoo7
11
03-25-2012 05:58 PM
JDM_WHR
10
06-07-2010 08:50 AM
