How do you? make wholes in ecu.
Re: How do you? make wholes in ecu. (THC1107)
Get a solder gun and desoldering wire from Radio Shack or a similar store. I heated the solder from the back side while touching the desolder wire from the other side to get it out, just don't leave the solder gun there too long or you'll burn the board up
Re: (wob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wob »</TD></TR><TR><TD CLASS="quote">it looks desoldered already... what other holes do u want to make</TD></TR></TABLE>
hes asking how to get them like that.. reading comprehension owns you
spelling/grammer owns me
yes, i just took solder gun.. on low setting, heated up from back, and stuck the solder tool on front.. its like a 'vacume' and sucks the hot solder out
Unceasing Measure
Re: (THC1107)
Just get a 3/16th bit in there are git er done, hillbilly.
Whole = 1 Containing all components; complete: a whole wardrobe for the tropics.
1A Not divided or disjoined; in one unit: a whole loaf.
Hole = 1 A hollowed place in something solid; a cavity or pit: dug a hole in the ground with a shovel.
1A An opening or perforation: a hole in the clouds; had a hole in the elbow of my sweater.
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the fact that you're asking this means you should leave it to someone that knows how to work on electronic circuit boards.</TD></TR></TABLE>
Re: (THC1107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 »</TD></TR><TR><TD CLASS="quote">ONLY ONE WAY TO LEARN</TD></TR></TABLE>
There are better ways to learn than frying your ecu. If i were you I would read up before you just take a soldering iron and put it to your ecu because "someone on the internet" said it would work.
And its hole not whole
Re: (eXcelonTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">I'm saying it will work, now if he does it right I can't say anything about that</TD></TR></TABLE>
I know but when you say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">just don't leave the solder gun there too long</TD></TR></TABLE>
To someone that has no experince or previous knowledge in how long it takes for a soldering gun to kill a board Or what kind of heat the soldering gun is capable of producing I bet they will leave the soldering gun on the board for too long and fry the board.
Re: (94_HATCH)
True, but if they don't understand when i say too long, red light should be going off in their head that they shouldn't be doing it. Also, i don' think anyone should be using an ECU or circuit board as their first soldering experiance even if they have a 25+ year master electrcian next too them. But i see where you're coming from
Re: (eXcelonTypeR)
Didn't mean to say you were wrong...just trying to let the person that posted the question know that there is a bit more to it. Im sure you know what your doing but im also sure he doesn't.
Re: (94_HATCH)
i know how to heat sink. i got a ecu to learn on. Please just help and dont tell me to just have somone else do it. I not so joe. DIY
Re: (THC1107)
ok, well you have a few choices.
from cheapest to most expensive:
1.) solder wick:
2.) solder sucker
3.) desoldering iron
Some of the pads are kind of close, be careful not to have solder make any unwanted contacts!
1.) solder wick:
2.) solder sucker
Re: (B18EG6)
...even more $$ yet
and what I use regularly.
All though solder wick does work good with some practice. IMO your ECU is not a good place to start learning to solder.
Location: Holley 4053, carb 406 stroker anal Luber, Fag
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">...even more $$ yet
All though solder wick does work good with some practice. IMO your ECU is not a good place to start learning to solder.</TD></TR></TABLE>
wow what kind of work do you do? That's pretty much the best money can buy.
Re: (THC1107)
You could use the extra part of a resistor lead if you wanted. Or pretty much any kind of solid wire as long as it isn't too small or too big.
Solder 60/40 rosin core solder
60% tin 40% lead.
I wouldn't get one of the cold heat things from radio shack.
Heres a pretty good thread from a little while ago
https://honda-tech.com/zero...34698
60% tin 40% lead.
