intake mani.
intake mani.
I picked up a skunk2 pro series intake manifold, and i am putting a new intake mani. gasket on it for sure,
now my question(s) is/are do i have to replace the throttle body gasket, and when i swap the injectors from the y8 mani to the skunk2 mani should i get new clips?
thank you
thank you
Re: intake mani. (tuck'd98)
im for sure u can use your stock throttle-body . . BUT !! the point is that your getting a after-market intake manifold . . which lets the engine suck in more air . . but how big (mm) is your stock throttle-body ? . . so basically you will be restricting air-flow being able to get inside . . unless a after-market throttle bodie is then equipped to it . .
just as long as the throttle body is smaller than the intake manifold bore, things wouldnt get messy besides the fact that the tb will be the bottle neck. everytime u take off your tb you should get a new gasket for that.
i would suggest porting the tb to match the bore of the intake manifold
* B A N N E D *
1 Post
Re: intake mani. (lemon_juice)
If your car is not a EX, then you have the shitty y7 IM, and anything else is a improvement. Get a new TB gasket, i got one offline when i ordered parts from hondaautomotiveparts.com it was like 3 bucks.
you do not "swap" injectors. Take all of em out and the fuel rail. you re-use your fuel rail and fuel injectors. the rail/injectors are bolted on with the bolts on those sticks, and snug into the IM with 4 rubber seals that you coat with oil before installing. I bought new ones only to find the old seals were perfect. So no parts needed really.
Re: intake mani. (Redline96LX)
thanx alot for the help, and yes my car is an ex, but i may get a b18b(Ls) throttle body.
I was hoping i didnt have get new seals for the injectors, since in spring my car will be turbo, so im just putting this one now for ***** and giggles and later upgrading to 310cc injectors
also the pro series is desgined for a stock throttle body, but you can always upgrade to something bigger
ShinotakuX
09-09-2008 09:21 AM
Integacivic
07-31-2004 01:59 PM
