*** HELP: Turn Signals Not Working ***
I have a 1996 civic HX coupe. The turn signals stopped working. Before it stopped working, it would blink like twice and then it would stay on solid. Then after a while, it just completely stopped working.
I replaced my turn signal relay and that didnt solve the problem. My hazard lights do work, but when i signal left and right, they do not.
Any suggestions on stuff i can check?
Thanks In Advance.
-integlspwr-
Thanks In Advance.
-integlspwr-
Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 »</TD></TR><TR><TD CLASS="quote">Did you check fuses? Grounds? any shorts?</TD></TR></TABLE>
fuses = not yet. (do you know which fuse should i be checking to see if its burnt?
grounds / shorts = not even sure where to start to check those..
Re: (NAisBEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">does everything else work, such as your instrument panel lights?</TD></TR></TABLE>
the cluster lighting works, so does the lighting behind the climate control area...
Re: *** HELP: Turn Signals Not Working *** (integlspwr2k)
relay/flasher is bad. when the lights were staying on that was the relay/flasher sticking. then when it stopped working that was the relay/flasher poping. so just change the relay/flasher and your good..
Re: *** HELP: Turn Signals Not Working *** (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">relay/flasher is bad. when the lights were staying on that was the relay/flasher sticking. then when it stopped working that was the relay/flasher poping. so just change the relay/flasher and your good..</TD></TR></TABLE>
i did change my relay / flasher to a new oem one from the dealer, and still no turn signals.
Re: *** HELP: Turn Signals Not Working *** (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">check your underhood fuses. you probably blew your hazard fuse</TD></TR></TABLE>
but my hazards work when i press the hazard button...
Year 3030
do your tail lights light up? i can garantee its probably just a fuse. Especially if both of them are out at the same time.
Re: *** HELP: Turn Signals Not Working *** (sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumslapper »</TD></TR><TR><TD CLASS="quote">do your tail lights light up? i can garantee its probably just a fuse. Especially if both of them are out at the same time. </TD></TR></TABLE>
ya tail lights work, brake lights also work.
I'll check the turn signal fuses tommrow and post back.
ricsosan_no5
11-02-2007 09:05 AM
FBP Si 2000
12-23-2003 05:16 PM
