engine swap help!!!
engine swap help!!!
Hey everyone sorry for asking but ive search an couldnt find much but i was wondering if the 97 civic ex harness will plug and play with the obd2 b18b motor or will i have to redo the wiring harnesses?
* B A N N E D *
Re: engine swap help!!! (DCshoecompany)
you will keep the same harness. and the ObD 1 fuel injectors, alt and starter, the distributor you Will use the OBD 2 and just ree-pin it to the OBD 1 plugs. and that is basically it the rest is just plug and play.
any other Q.'s I'll be glad to help.
hope that this answered your question.
Re: engine swap help!!! (mustang5.slow)
thanks for that part of the info so the the 97 civic ex are obd1? what distributor do i need to use civic or the integra? and if the 97 ex was the single cam vtec motor will the harness still have the same fitment as what u describe? thanks if you could help out agian...
* B A N N E D *
no they are OBD2 and you can use the OBD 2 distributor with your OBD 1 harness.
and you will have to wire your vtec plugs. and get a p28 ECU.
BTW no prob. keep asking.
I don't really like mustang5.slow's information on this one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCshoecompany »</TD></TR><TR><TD CLASS="quote">Hey everyone sorry for asking but ive search an couldnt find much but i was wondering if the 97 civic ex harness will plug and play with the obd2 b18b motor or will i have to redo the wiring harnesses?</TD></TR></TABLE>
You don't have to do any plugs on the harness. The harness is OBD-II, the motor is OBD-II. It's 100% plug and play as far as plugs go, you don't need to use a diferent starter, alternator, nor injectors as mustang5.slow led you to believe.
Also, you can't use a P28 ECU without a conversion harness - and it's completely worthless if you did. Chipping an OBD-I ECU to run an LS basemap is probably the biggest waste on an OBD-II car.
Just plug in the stock LS ECU, it'll work fine unless the motor is 99/00 in which case you'll need a OBD-IIa to OBD-IIb conversion harness.
If you were to go with an LS/VTEC you'd need to tune it, so you'd have to go with a OBD-IIa to OBD-I conversion harness and run either a chipped ECU, or a tunable ECU such as AEM or Hondata.
Re: engine swap help!!! (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">I don't really like mustang5.slow's information on this one...
If you were to go with an LS/VTEC you'd need to tune it, so you'd have to go with a OBD-IIa to OBD-I conversion harness and run either a chipped ECU, or a tunable ECU such as AEM or Hondata.</TD></TR></TABLE>
thanks for that info it will be very useful to what i have planed for my car..also can i do the OBD-IIa to OBD-11b harness conversion my self or is there web sites that sells them?? thanks agian i have thought about it and am goin to do LS/VTEC
another question would i have to get diff exhaust pipping or will my stock ex pipping bolt up to the ls motor?
thanks for that info it will be very useful to what i have planed for my car..also can i do the OBD-IIa to OBD-11b harness conversion my self or is there web sites that sells them?? thanks agian i have thought about it and am goin to do LS/VTEC</TD></TR></TABLE>
the engine harness would be a plug n play, the difference in the obd2's are the ecu's.
here this might help you for the vtec wiring on the lsvtec question:
http://www.rywire.com/store/
QUOTE=philosofy1]
http://www.rywire.com/store/[/QUOTE]
Does anyone know if i have to get a exhaust system or would my stock bolt up the ls stock headers????[
ohsnapzafingcu
21
11-12-2008 02:22 PM
vtec25
10-09-2005 05:49 PM
ITR1071
09-15-2002 09:09 PM
