High Engine temp @ red lights
I have a 99 ex, 5 speed 112,000 miles. Every time i stop at a red light regardless of temp outside my engine sky rockets to a hair under the red. As soon as i go it drops back down. What i've heard is my fan might be 2 speed, one for cruising and a higher speed for sitting still. I popped my hood and fan is spinning. So could this be a fan speed controller issue, radiator fluid????? i don't have a clue
Re: High Engine temp @ red lights (cainalan03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cainalan03 »</TD></TR><TR><TD CLASS="quote">I have a 99 ex, 5 speed 112,000 miles. Every time i stop at a red light regardless of temp outside my engine sky rockets to a hair under the red. As soon as i go it drops back down. What i've heard is my fan might be 2 speed, one for cruising and a higher speed for sitting still. I popped my hood and fan is spinning. So could this be a fan speed controller issue, radiator fluid????? i don't have a clue </TD></TR></TABLE>
so for sure you know that your fan is spinning. the radiator fan right? not the condensor fan.
if that's the case i would replace the thermostat, then go from there.
kk i went out, turned on the car and let it run. as soon as temp gauge started climbing the radiator fan did turn on as did the condensor fan. but temps kept the same.... only turning off a/c kept temps lowER but still well above normal.... any other ideas?
You sure the wires aren't switched on the fan? If they're in backwards and it's spinning backwards it won't really help.
ha i guess i can look but i haven't touched it, then again i'm not the first owner... but the car didn't do it when i first got it ( march) and i first noticed about a month ago... the POS has been driving me 92 miles a day back and forth to work every day so i can't complain.. but i don't want it to die on me and be out of work.
H-T White Ops
Low on coolant. Check it. $5 says that when the engine's cold and you pop the radiator cap you can't see fluid in there. Same thing happened to mine. Burning coolant. Mine's because of a head gasket that's waiting to go out.
Re: (IslandSi)
Check the coolant, change the t-stat, also check the wiring on the coolant temp. sensor, and either fix or possibly replace. you're symptoms sounds exactly like mine use to be. Car would bury on H when stopped for an extended light or sitting at idle somewhere. At driving speeds, stayed at cool/normal temp. One wire split off of the connector for the coolant temp sensor. Just a thought.
awsome thanks for the help, i will start out with the cheapest fix... the coolant, sometimes you get lucky. then go t-stat and so on... all of you justc ross your fingers its not the head gasket..
and lol @ lolyouhavefakewheels.... i agree
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cainalan03 »</TD></TR><TR><TD CLASS="quote">all of you justc ross your fingers its not the head gasket.. </TD></TR></TABLE>I could care less about YOUR headgasket. Not gonna lose any sleep if YOUR headgasket is going out.
Again,
Again,
0ne-Cam
11-06-2009 07:52 AM
Nocturnal
11
06-21-2004 01:02 PM
