white wire on MSD Digital SCI+
White Wire-This wire is used to connect to the points, electronic ignition amplifier output or to the yellow wire of the MSD timing accessory
WHEN THIS WIRE IS USED, THE MAGNETIC PICKUP CONNECTOR IS NOT USED.
where exactly is the points or the electronic ignition amplifier output?
i searched and couldn't find anything
Re: white wire on MSD Digital SCI+ (Winlight)
also,i mounted it in the glove box and im going to put a small fan in there to keep it cool.has anyone tried that yet?
http://www.msdignition.com/1download.htm
go down to where the pic is showing honda and you should be ok on the SCI section
Re: white wire on MSD Digital SCI+ (saleensolution)
when i tried it the first time i hooked it up wrong,but now it looks to be right but still wont start.i swapped the coil with the one out of my h22a and still no luck.the light comes on on the side of the box but it wont start.what should i check first?im going to follow the directions to check to see if the box is still good in the morning.is there any fuses i could have blown when i had it hooked up wrong?
drtysohc
15
09-29-2007 11:42 AM
