Running 5 wire o2 on z6 p28
Ok. I got my d16z6 swap into my vx I kept my vx harness and the 5 wire o2 sensor. I ran my p07 ecu on the z6 for a while, then I got an auto p28. I've been running my vx 5 wire o2 sensor on my z6 with the p28 for a while and seems to be running ok. Will running the 5 wire only give me a CEL because I really don't care, or is it bad, should I rewire for a 4 wire?
Re: Running 5 wire o2 on z6 p28 (CapnKrunch)
anytime the chk engine light is on the vehicle wil run on last known good parameters so you probally arent getting as good as mpg or hp go back to a 4 wire
Re: Running 5 wire o2 on z6 p28 (gsrhatch2356)
But I'm wondering specifically what this will do accept throw the code of course for being the wrong o2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 »</TD></TR><TR><TD CLASS="quote">to be honest with you i have never seen a 5 wire but i do know what happens when the mil is on</TD></TR></TABLE>
mil??
mil??
the five wire O2 is actually a wideband, it will set CEL#1 in the P28.
unless your running an auto swap you need to pull open the ECU and remove RP17 and RP18, then solder a jumper across RP17 to get rid of CEL#19.
Any CEL is bad, it will drop your MPG and makes the car slower.
rewiring for a four wire O2 is really easy with the VX harness, if you've all ready adapted the O2 wires to accept the 4-wire O2 that is.
one wire to switch at the ECU and it will work fine. If you'd like to go down this path let me kow, I can tell you which wire to move.
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the five wire O2 is actually a wideband, it will set CEL#1 in the P28.
one wire to switch at the ECU and it will work fine. If you'd like to go down this path let me kow, I can tell you which wire to move.</TD></TR></TABLE>
I have a 5 speed swap, so thanks FYI on the auto to manual conversion.
So I have the 4 wire o2 sensor itself and I have not adapted it to fit to my harness (I still have the 5 wire left on there and the harness is unmodified). I don't have the inlet for the 4 wire o2 sensor to plug into (the one on the harness) but I can get it from my friends z6 harness I got the auto p28 from, or can I just wire it onto the 5 wire inlet/outlet plug thing?
So what exactly will I have to do to get this 4 wire o2 on there and not throwing any CEL's?
Built B16A
10-18-2004 03:10 AM
trooper0641
34
04-23-2004 12:29 PM
