del sol help
del sol help
ok what is this i cant get anyone to tell me what his does. could this be the pvc? could this impede high throttle if the tube on there was pinched? need help fast please.
Re: del sol help (cyb593)
Im not to sure what it does but on my car i have a short ram intake and where the hose is on the motor, i have a small cone air filter. I dont know if this helps you at all.
That is just the fresh air tube for the crankcase ventalation system. The pcv pulls crankcase fumes thru into the intake. fresh filtered air flows from the air filter into the crankcase and then is sucked up into the pcv.
as long as the pcv isn't stopped up you shoudn't have a drivability issue and even if it was stopped up you probably wouldn't be able to tell, ecpecially at higher rpm's.
Later, Drew
Later, Drew
jonnybravo
05-23-2002 11:38 AM
