HELP: SWAPPING D16Y8 (OBD2A) MOTOR IN 95 HATCH (OBD1)
hey guys i serched and cant find anything... what all do I need to swap a d16y8 motor which is obd2a from a 1996 civic into my 1995 hatch which is obd1..
if you guys could help me out it would be greatly appreciated.. thanks
* B A N N E D *
Re: (gotboosthatch)
you will keep the same harness. and the ObD 1 fuel injectors, alt and starter, the distributor you Will use the OBD 2 and just ree-pin it to the OBD 1 plugs. and that is basically it the rest is just plug and play.
any other Q.'s I'll be glad to help.
Re: (924doorEG)
if you have an si, you need to use a cx/dx/lx distributor on the y8, reuse the alternator, starter and harness off of your old motor and everything else will plug up using a p28. depending on the model you might have to run extra wires for vtec and a different o2 sensor since the cx uses a 1 wire and the vx uses 5 wire. try to find an ex/si harness and you wont have to do wiring
Re: (gotboosthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch »</TD></TR><TR><TD CLASS="quote">I have a 95 vx.. So I can't use the p2p ecu made for the y8 motor?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch »</TD></TR><TR><TD CLASS="quote">I have an ex harness from a 93 ex which had a d16z6 in it</TD></TR></TABLE>
you can, but it would be alot easier to just use a p28 since your car is obd1. just use the z6 harness and it will be plug and play
6doorsentra
14
10-08-2006 11:36 PM
ErikDaGenErik
08-30-2003 01:09 AM
