Halo Headlight problems
i jus traded my stock headlights for some halo projectors the lights work high and low beam but i dont kno where 2 connect the halos for them 2 work.. does anyone kno where they go
Re: Halo Headlight problems (J3rm)
There isn't anywhere to just plug them it. What I did is spliced and soldered the wires into the running lights. It works great for me. The two blacks go into the running lights black wire and the two reds go into the running lights red wire.
Re: (smileycvc)
Not really.... Red is for Positive and Black is for Negative. There is no ground going into the running lights. If you look at it there are three wires.
Red = Positive
Black = Negative
Green = Positive for Turn Signals.
.... If you wired your red wires into the green ones then your Halo lights would blink in sync with your turn signals and would be off when you are not using your turn signal.
Red = Positive
Black = Negative
D Grade
04-05-2009 09:27 PM
JDM CIVIC TUNER
03-10-2003 01:40 PM
