1998 CIVIC EX SEDAN...
I have a question, hopefully someone can answer it fairly quickly...I can't get the trunk light to work. Isn't it supposed to come on when you open the trunk? How can I fix it?
Re: 1998 CIVIC EX SEDAN... (smarsha_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smarsha_2 »</TD></TR><TR><TD CLASS="quote">Is there some kind of actuator? Is there a actual fause for the trunk light? I don't get it...</TD></TR></TABLE>
should be a fuse for it...pull the fuse cover off the bottom of you dash...it should have a plastic paper on there and it says what fuse is what.
H-T White Ops
If you don't have the plastic fuse diagram sheet, you can see a full explanation here, and also print out a copy to save.
https://honda-tech.com/zerothread?id=1966666
h3adtr9p
03-26-2019 12:47 PM
