PICS!!!!!OF MY P.O.S
well this car was free so im gonna get it lookd at tomorrow by a local mechanic
but im trying to fix every thing i can as to cut down on the BILL
well any and all comments welcome preferably things i need to fix IE* missing fuse ,vac line ect. o and from the pics can someone locate the main relay for me thanks!!
Modified by xXSilentScreamXx at 11:43 PM 8/4/2007
Re: PICS!!!!!OF MY P.O.S (devney)
well i traded my 00 si with blown piston rings and 2 bad o2s and both window rails were jackd oo and it had a salvage title
H-T White Ops
Your upper grille is missing the inner piece (or it's cut out). You might want to later replace it with another '96-'98 grille. The coupe and hatch ones will look like yours, but Milano Red is only a coupe color and Roma Red is only a hatch color (can't see what your car is from here).
Oh, and this might help with fuses. Print yours out from it.
https://honda-tech.com/zerothread?id=1966666
PM'ed.
After you showed me that picture of the ECU harness, that's 100% definitely the problem, it's shorting out or not connecting someplace.
Solid CEL = No response from ECU, which means it's either dead or the wiring is fucked. That wiring is OWNED 6 ways from Sunday. I'd chop it off higher up (maybe by the glove box) and wire in new plug ends from a junkyard harness.
Stouts 'n' Scotch
Re: (xXSilentScreamXx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">how much you think the shops gonna charge for all the wireing? </TD></TR></TABLE>
Alot. It's very time consuming and time = $$$$ when talking labor charges. Try to do as much of it yourself as possible.
Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Alot. It's very time consuming and time = $$$$ when talking labor charges. Try to do as much of it yourself as possible.</TD></TR></TABLE>
Yeah, but at the point he's at, he might be better off getting a quote from an automotive electrical shop.
It's a mess, somebody went to work on it and messed it up. Get a quote from an auto electrical shop.
was this free or did you trade for it?
well i traded my 00 si with blown piston rings and 2 bad o2s and both window rails were jackd oo and it had a salvage title "
i'm guessing with the questions you're asking you have no idea how to fix this thing, taking the si to a shop to be fixed will most likely end up having been cheaper then the mess you're about to jump into.
Re: (k powered ej1)
i was fing with various ecus none of them prime well accually syn im gonna take a better pic of the harness bc its not that bad
the wire i was refering to was that ornage one which is cut *idk the guy working on it did some 3>2 wire iacv? or something* i thought if my main relay went out my car wouldnt prime? but hes right about the solid cell ****
somehow my ecu isnt sending/receiving **** so i need to fix it
see after i caught them in the act of riping my engine out the cop told them to pit every thing back or get sued and i had to leave when they were *putting my car back together* so they stole my p28 abd god knows what they did to my car what i might do is drop the engine and buy a mint white ek shell would that work?
H-T White Ops
Re: PICS!!!!!OF MY P.O.S (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">what the hell, where's the ******* tech?</TD></TR></TABLE>
Right in post number one. He bought a car and wants us to tell him some things he should pick up to get it up and running.
Re: PICS!!!!!OF MY P.O.S (xXSilentScreamXx)
Where at in texas do you live, I wire up swaps all the time. it can be very time consuming depending on what motor you get. the b-series are easy and only take about a hour if that. but if you live close I could help you out for alot cheaper than a shop will. most shops are at least 80 bucks a hour and that is cheap and go up to 110-120 and hour
