Replacing Inner & Outer Tie Rods - what should be replaced on steering gearbox
This is on a 1994 DX Hatch - non power-steering
I will be replacing inner & outer tie rods... boots & ball joints will also be replaced. what other parts (tie rod or steering gear box related) should be replaced for preventative maintenance? please post #'s from diagram
http://www.slhondaparts.com/br...=true
these guys are reputable BTW with good prices & their parts really are oem quality
-tie rod set http://cgi.ebay.com/ebaymotors...wItem
you have to inspect under the car and determine if something is bad...I replaced the whole raqck and pinion since the outer tie rods were fused to the box and could not be removed without cutting them off
Re: (vrrodri)
i thought there was some bushing on rack that people suggested replacing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri »</TD></TR><TR><TD CLASS="quote">you have to inspect under the car and determine if something is bad...I replaced the whole raqck and pinion since the outer tie rods were fused to the box and could not be removed without cutting them off</TD></TR></TABLE>
did you have the special tool for removing inner tie rod ends?
FrontwheelENT
08-31-2014 07:49 AM
msinsky14
15
05-03-2007 11:21 AM
