2 bolts to secure the ac compressor, strong enough?
i swapped a b16a into my eg and was told that del sol ac bracket will work on my old d series ac set up
but i tried to bolt the old d series air compressor to b16a oem ac bracket..
and only one side (upper and lower bolts fit)...
and with only 2 bolts to secure the ac compressor and it is not shaking or moving or virbrating when i try to move it my hands..
cause my eg is still down..cant fire it up yet..cant test it yet when it is running.
so my question is ....is it ok and safe to just secure 2 long ac bolts to an ac compressor?
please advise.
thanks
please advise.
thanks
Re: 2 bolts to secure the ac compressor, strong enough? (crazyguy)
Are you using the Del Sol bracket? The JDM B16 bracket wont work. If its the Del sol bracket and its hooked up secure then the other 4 should bolt up. If your only going to run 2 make sure there across from each other, like top left to bottom right or top right to bottom left. Not top left bottom left, top right bottom right, top right top left bottom left bottom right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">yeah i am using jdm b16a bracket..
sell it
sell it
Yea thats not the right bracket at all. Has to be USDM Del sol or CRV.
jeffhoe
05-22-2013 05:03 PM
