car only runs on 3 cylinders? dsm injector wiring w/ inline resistors?
My car is only running on 3 cylinders and i dont really know why..........i was pulling out of burger king and i didnt even punch it, it just started bogging down and the lights were getting dimmer, but i drove it about 2 miles home going about 25 and then when i got home i noticed one of the resistors for the injector wiring was broken off. so i rewired it how it is suppose to be with the resistor going to the black and yellow signal wire on the injector clip and the harness and also got a brand new ecu with my chip in it but now it still only runs on 3 and when i unplug the injector clip the idle doesnt drop.......any suggestions? could it be that my chip just went bad? thanks
-my setup-
97' civic
built d16 w/ gt28 turbo
converted to obdI, tuned on crome w/ dsm 450s
-my setup-
97' civic
Re: car only runs on 3 cylinders? dsm injector wiring w/ inline resistors? (MBlake55)
I had the same issue when I was boosted. Re-soldered the injector that wasn't working, and was good to go.
You sure all your connections are solid?
Re: car only runs on 3 cylinders? dsm injector wiring w/ inline resistors? (Forty04)
ya all the connections are solid but i might have the resistor on the wrong wire i have a black and yellow wire and then a red wire coming from the harness? which one gets the resistor? thanks
also could something else have blown? cuz i have a brand new ecu with my chip but idk wat else could go wrong.........
okay all the wiring is correct because i just checked it, from the injector wiring to the harness to the ecu.........wat else could it be?
Re: car only runs on 3 cylinders? dsm injector wiring w/ inline resistors? (isaacson06)
i have dsm 450s but how can i test them besides taking off the fuel rail and seeing if they all spray? could i hook up my stock injectors with my stock ecu and just start it to see if it runs on all 4 cylinders?
bump all the injectors are getting fuel and spraying i have spark in all 4 cylinders.........when i unplugg the injector clip for cylinder 1 the idle doesnt drop so its definitely wiring but idk where anyone?
hey m having the same isssue??.... did u resolve it... i'm having it with the RC 750z... it runs gud if u plug in the stock ones.. but goes into 3 cylinder mode on the bigger injectors.....if u resolved it do temme how??..
thanks
thanks
MBlake55
08-08-2007 07:29 AM
