air conditioning question
sorry if this has been posted a billion times, if i buy a swapped car (b-series into...mid 90's civic) with no a/c, do i need a/c equiptment to match the car or the engine?
Re: (97Ej6mike)
what about the rest of it, will the mounts from the b-series work in the civic? or do i need the whole setup from the civic and the b-series compressor? would they work together? or the whole b-series setup with civic mounts? would that work?
Guest
Posts: n/a
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">You will need the A/C compressor specifically for a B-series motor.</TD></TR></TABLE>
No- you want to get either a p54 or a crv ac compressor bracket, and then run this-
http://www.hondaautomotivepart...R+KIT
Re: (vestalfootball72)
thanks for the help, but i was hoping to go a little cheaper if at all possible, if i found all the stock a/c parts that were original to the car from someone who had pulled them from their own car, and a compressor to go with the motor, would that work together?
get a del sol vtec bracket or a crv bracket (maybe p7j). you can then use everything from a civic. compressor, condensor, drier, lines, everything.
Re: (grg3135)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grg3135 »</TD></TR><TR><TD CLASS="quote">ok, just so were clear, were talking about the compressor bracket, right?</TD></TR></TABLE>
YES. We are ALL talking about the Compressor Bracket.
The stock GSR Compressor bracket will NOT work with your stock, D-series, A/C compressor.
You're options are to use a Del Sol VTEC compressor bracket or a CRV compressor bracket with ALL stock to the car, D-series, A/C components.
Here are the parts numbers for both.
CRV - 38930-P7J-000 - $64
Del Sol - 38930-P30-000 - $104
Prices are from Majestic Honda.(Click on Name for link) Great place to find and buy cheap OEM parts.
stehigs321
05-08-2004 02:20 PM
