Axle Shaft replacement: Which brand?
Car: 1995 Honda Civic Ex / Vtech / 5-speed / coupe
The passenger-side inboard joint boot is torn apart. About 4 years ago (40K miles ago) I had this same axle shaft replaced (Honda OEM part) because the outboard joint boot had torn apart and was causing a clicking sound when I made left-turns.
I know I have to replace the axle shaft again. Instead of getting a brand new OEM Honda part this time, I'm thinking of maybe an aftermarket axle shaft or a remanufactured Honda part. Does anyone have experience (good or bad) with the following brands? Or can anyone recommend a brand?
1) Brand new Honda OEM ($420)
2) Remanufactured Honda ($205)
3) A1 Cardone ($80)
4) Empi ($92)
5) Arc ($66)
6) CVU ($73)
3) A1 Cardone ($80)
4) Empi ($92)
5) Arc ($66)
6) CVU ($73)
Re: Axle Shaft replacement: Which brand? (JJSpecTuning)
OEM axles are $273 @ HondaPartsDeals.com, but you can get one for $70 at your local parts store with a lifetime warranty.
Re: Axle Shaft replacement: Which brand? (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">advanced auto with the lifetime warranty, i paid about $60</TD></TR></TABLE>
X2
After you turn in your core, you get like $40 back. Lifetime warranty is the best
X2
Re: Axle Shaft replacement: Which brand? (gtlaw1)
go with napa or auto zone. but if u want summin thats gonna hold up to alot more hp than stock (i dont know what ur set up is) i would recomend http://www.driveshaftshop.com/item170655.ctlg there alil more expensive but will hold up to the power alot better and they dont mind being launched alot.
