94 Del sol door question
* B A N N E D *
Hello, well i just bought a del sol and the only problem with it is that i cant open the door on the driver side from the outside but i can open it from the inside. How would i be able to fix that? And yes the car is unlock LOL.
Re: 94 Del sol door question (PinoyDelSol)
Take off the interior door panel. Sounds like something from the outside handle to the release is broken.
John
John
Sounds like the rod that connects the exterior handle to the latch mechanism is broken or has come off for some reason. In order to investigate this further you'll need to pull the interior door trim panel off. If you have experience with this it should be no problem, if not, a body shop would probably look at it for around $40. If you have some minor tools and are confident in your abilities with this sort of thing then I'm sure once you see what's wrong it shouldn't be a big deal to fix.
toben
02-24-2007 08:05 PM
Alexander
10
11-23-2004 11:02 AM
