Eg6 gauge cluster
Eg6 gauge cluster
Hi I have a 92 honda civic and I wanted to know if the EG6 gauge cluster will work on it?? By the way it has a B18a1 swap into it but for some reason the MPH gauge does not work, only the RPM's and rest of the lights work, I took it out to check if the wire hardness plug wasn't plugged in but it is... what can it be???
Re: Eg6 gauge cluster (92hondaswap)
This should probably be in the Civic section but anyways which VSS did you use in the swap because the B18A1 has a cable VSS and the Civic has a electronic.
Re: Eg6 gauge cluster (PACT man)
I didn't do the swap myself, I had already bought the car as is.. So maybe that's why the gauge isn't working... I'll post this up on the civic section and find out how can I get it to work. thanks!!
