Hi guys, need help with idle!!!!
I got a d16z6 head on my d15b7, reg boltons (i,h,e) and since i did it i been having probs with idle 1st someone told me that the head needs more gas and to increase idle by adjusting t-cable, but its not working when i deprese the acc pedal idle goes to 2000rpms and if i pull the pedal out with my foot it goes back to normal, it seems that gets stock or something, any halp will be appreciated guys!!
Re: Hi guys, need help with idle!!!! (demian22)
make sure t-cable is not too tight or loose. clean iacv.check tps voltage. if you dont know how to adjust tps, run a search by "tps adjustment" at this forum
Re: Hi guys, need help with idle!!!! (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">make sure t-cable is not too tight or loose. clean iacv.check tps voltage. if you dont know how to adjust tps, run a search by "tps adjustment" at this forum </TD></TR></TABLE>
what he said ^
what he said ^
