Gear Shifting PROBLEM?
I went to drive my car today to school I let it warm up because it is -25 here where I live. When I went to drive it, it would not go into gears like you have to push with all your strength to go inside a gear it does not matter which one 1,2,3,4,5, or reverse. I let the car warm up more and went to school barely because I had a mid-term and had to make it. When the school was done I had the same problems the pedal was soft really really soft and the car would not go into any gear, but when I turn it off it goes smooth from 1st to 5th and reverse. Did anyone have this problem or knows what the problem is I would appreciate it if anyone would help?
Re: Gear Shifting PROBLEM? (Djole_V)
sounds like your clutch slave cylinder seals are probably gone..check around the cylinder for fluid and leaks and check the resovoir it is probably low..
turbo66000
Transmission & Drivetrain
08-26-2008 05:43 AM
982drLS
06-12-2004 04:44 PM
iperez
07-06-2003 10:24 PM
