big problem..need all the help i can get...
Old 02-11-2008, 09:15 PM
94eh2's Avatar
Default big problem..need all the help i can get...
well i finished swapping in a 99 gsr swap into my 94 eg hatch..everything went great..all mounts are good and tight all hoses good..wired up..perfect..axles in put back my suspension..but now there a problem..wen i go over 10 mph the front end of the car starts shaking violently ..like if the lug nuts were really loose..but there not..i cant seem to figure out the problem..i switched out the axles ..still no luck..can something have happedn during the swap to the inside of the tranny that would cause this? please need this fixed asap..thanks
Old 02-11-2008, 10:08 PM
VRD^don's Avatar
Default Re: big problem..need all the help i can get... (94eh2)
go back and retighten all nuts/bolts that you loosen. hub nut tight? mounts ripped?
Old 02-12-2008, 01:46 AM
slowcivic2k's Avatar
If the car was moved with no axles in it the wheel bearing may be separating, Like he said check the axle nut. You may have ruined a wheel bearing.
Old 02-12-2008, 02:17 AM
crazyguy's Avatar
front lower or upper lca bushing might have gone bad.
Old 02-12-2008, 05:40 AM
bmgangsta's Avatar
Are ur bushing even good at all
Old 02-12-2008, 05:57 AM
laocivic's Avatar
Default Re: big problem..need all the help i can get... (bmgangsta)
make sure u tighten that nut with the cotter pin on the Camber arm thing on top of the spindle.....That ***** happens a lot. just a thought cuz i've seen wheels wobble side to side while driving cuz of this
Old 02-12-2008, 06:43 AM
94eh2's Avatar
Default Re: big problem..need all the help i can get... (laocivic)
i double checked everything..i have a new camber kit in the front so all the bushings are new...anyone else
Old 02-12-2008, 07:38 AM
b18cDelSlo's Avatar
what axles you have? they could be too long/short
Old 02-12-2008, 07:39 AM
b18cDelSlo's Avatar
Default Re: big problem..need all the help i can get... (b18cDelSlo)
my buddy's crx did this and one of the axles was like 1/2 inch too long
Old 02-12-2008, 08:41 AM
94eh2's Avatar
im using b series axles..the same axles that were on my last gsr swap..i never had this problem until now..
Old 02-12-2008, 08:44 AM
IIXtremeHansen's Avatar
maybe unbalance tires? bubble?
Old 02-12-2008, 09:37 AM
thisisntjared's Avatar
Default Re: big problem..need all the help i can get... (Dickies_n_FlipFlops)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">maybe unbalance tires? bubble?</TD></TR></TABLE>a really big bubble for 10mph.
do you feel the shaking through the wheel? pedals? linkage? dash? everything? just shaking could be lots of things.
Old 02-13-2008, 03:42 PM
Default Re: big problem..need all the help i can get... (thisisntjared)
Did everyone just forget about the wheel bearing? I think that deserves the most attention.
Old 02-13-2008, 05:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared &raquo;</TD></TR><TR><TD CLASS="quote">a really big bubble for 10mph.
do you feel the shaking through the wheel? pedals? linkage? dash? everything? just shaking could be lots of things.</TD></TR></TABLE>...
thunderboy
10-30-2009 02:03 PM
EG2ENVY
26
07-14-2008 04:59 AM
si937
04-01-2005 01:55 PM
servion
07-07-2003 07:06 AM
wizzards581
06-19-2003 06:29 PM
Quick Reply: big problem..need all the help i can get...
