well need help find out if obd0 or obd1
ok well i have a 92 civic si hb and the guy before me had a lsv in it and now i am having problem hooking up my b16 it is not idling right at all .
well some one told me that i could have a obd0 setup and runing a obd1 ecu is that true and how could i tell ????
i am new to this stuff need some help bad if u need to know more just ask wat u need to know to help out i am going to try get some pick
i am running a p28 chipped should i get a pr3????
Re: well need help find out if obd0 or obd1 (bulitassb1692)
your car is obd-1. and you need to be more specific on the motor cuz there is about 3 or 4 different b16's. there is one that is obd-0, obd-1, and obd-2. whats your exact engine code? and a p28 is a d16z6 ecu...so yeah you need a b16 ecu.
Re: well need help find out if obd0 or obd1 (slo_hatch)
what chip r u running in the p28? u could just change out the wiring harness. that would probably be easiest
then you probably have the obd-1 jdm b16a from hmotorsonline.com. thats my guess. there is a way to tell if it is obd-1 or obd-0 but im not sure how. how many o2 sensors do you have? if you have 1 its obd-1 and if you have 2 or 3 im pretty sure its obd-2.
well if it just says b16a on ur block then u have an obd0 motor. the p28 is fine for ur motor as long as the chip is good. im running a chipped p28 on a b16a in a eg also.
Re: well need help find out if obd0 or obd1 (laocivic)
well is there like a obd0 p28 and a obd1 p28??? cuz i am just havening trouble getting it running like runs and idles ruff bad and vtec and working u think the chipp could be bad idk what kinda chip it is are any thing
ya i jsut got a new gsr trans put in and he did ngk plug wires and everyt hang but idk much about them so idk ya idk i am going to do the pins on my ecu strait to my sensor tha tmy map sensor, knock sensor do u think one could be bad ???
NewBorn_EG
11-06-2004 02:13 AM
