D15b Swap but is vtec running?
Ok i have a motes chipped Computer and i did a d15b swap from a d16z6, is there anything i have to do in the computer to allow vtec to hit.
Last night i let it warm up for about 30 mins and went out on the road and punched it and nothing then i came back in and read about a Vtec light, http://home.earthlink.net/~civ....html . anyway so i checked my wiring and nothing.. but i didnt make it a perm install just to check to see if vtec is working. so my questions is
how do i check to see if vtec ever comes on?
Do i need to reprogram my chip? and which bin should i use. (Currently i have a d16z6 chip with higher fuel maps i think)
can i test a vtec with a wire tester?
Thanks again for your time
Shaun AKA Commotion
Shaun AKA Commotion
Re: D15b Swap but is vtec running? (commotion)
u don't have to chipped again it should work fine and yes check if the vtec work if not switch it with the other engine!!
Re: D15b Swap but is vtec running? (chuisek9)
will that vtec work? eventhough it comes froma d16z6? i thought the jdm one was a 3stage and the USDM one is a 2stage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuisek9 »</TD></TR><TR><TD CLASS="quote">connect a stray wire from the positive and see if it pop open </TD></TR></TABLE>
thats right
thats right
SargeSlapnuts
10-28-2009 09:57 PM
2slow4stock
17
04-26-2007 04:45 PM
sloweredcivic
04-09-2004 07:40 PM
