what is the cost for a starter replacement?
the wire that connect to the starter got ripped for some reason, I tried solder them back but it wouldnt connect, so is getting a starter the only option for me? if so does it come with the starter wire? and how hard is the installation process? thank you .
Re: what is the cost for a starter replacement? (ShinotakuX)
why would you need a new starter if the wire that connects to it is bad?.. or is it the selinoid wire going to the starter thats bad?
Re: (MasterShake)
is the wire that you can see from the top of the hood, I dont know how to explain it, but is the wire that connects to the starter from outside i believe. it is right under the dizzy.
just take it to a shop then, tell them what went wrong and let them replace the wire. its not that hard and cheaper than replacing a whole starter...
