will 91 crx function & forms fit on my 95 civic coupe or what mod is needed
Can i make these fit onto my coupe. I recently had my car in a fire accident but these are still good. Let me know anything plz there the type 2 and only had them for 3weeks on my car before it burned. thanks everyone
Re: will 91 crx function & forms fit on my 95 civic coupe or what mod is needed (nipcup101)
why view if u aint got nothing to say i need some to help with some advice thanks.
Re: (hondamonda)
wat about the back im pretty sure front will be fine with a fork change but the rear is my main concern. Thanks for the help
Re: (nipcup101)
I have a 91 DX EF and i used integra coilovers on the civic. What I did is change the front forks because the shock from integra were way to big so I use the integra front forks. And for the rear I did a rear disc brakes conversion so I had integra rear lower control arms. it depends what kind of Rear LCA you got because CRX has 2 types the ones that looks like integra type r and the regular one. Go under and find out first for the LCA
Re: (indoe247)
Incorrect on the rear needing ITR control arm. 1988 was the only year EF CRX that used that style rear shock. 89-91 used the regular "fork" type shock mounting on the bottom. For the fronts, just re use your CRX lower forks because the CRX front shocks are smaller diameter than the EG/EK/DC.
So yes, they will work with very little work.
Ryan
Ryan
northkai3
01-01-2010 10:36 AM
h4z4rdes
01-13-2006 10:44 AM
ilikemyaccord
04-27-2004 07:06 AM
