Spindle and Rotor Q's
Which spindles are the same? Im pretty sure all EG's are. But are any ef's or Ek's the same as EG hatch spindles? Same with rotors. I just had a wheel bearing go out so i just wanted to see when poking around the junkyard if there was anything else i could look at. Also are EG SI's the same? And Del Sol's.
Re: Spindle and Rotor Q's (Horseofcourse)
eg and ek's have the same spindles...you can reuse them...i know the egsi hatchs lx sedans brakes are a bit bigger than dx/cx...gl...if you could find some lx front spindles/lca's and sway bar, get that whole thing and swap them on your car if you don't have front sway bar....gl again!
project civic
06-01-2007 08:48 AM
Jon V
16
07-03-2004 06:54 AM
