bad tps cause no vtec?
throwing a code for my tps...and i noticed i havent heard vtec engage when i get on it....could this be the cause?
Re: bad tps cause no vtec? (jr000)
What engine?
If D series, I doubt you were hearing vtec engaging anyways. Splice a 2$ light(autozone/pep boys) into your vtec wire(the green one) and just let it dangle somewhere in your car. When you hit the vtec mark the light will turn on. Vtec lights are good for trouble shooting things like these.
I have a D15B and mine kicks in at 5500 rpm and you cant really hear a difference. I keep my vtec light by my ecu for when Im trouble shooting things like this.
Well run to your local autozone and grab that 2$ light I was talking about and splice it into your vtec power wire. You can easily do it in the parking lot and test it on the ride home.
Re: bad tps cause no vtec? (Mike"IAMSLOW"Myers)
lets put it this way...i know im not enagaging into vtec...you can hear it on a b16...also i am throwing a code for a tps...but i was just wondering if that is what may be causing vtec not to engage
Well, the only reason why I said to do that is because my TPS sensor is completely shot, I can unplug it or leave it in and theres no difference. But my VTEC still kicks in.
1 Post
yes the tps not working properly will keep vtec from engaging. i dont remember exactly how much throttle is required but if the car doesnt know exactly where its positioned it wont engage for safety of the motor.
Re: bad tps cause no vtec? (97civic94gsxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr »</TD></TR><TR><TD CLASS="quote">yes the tps not working properly will keep vtec from engaging. i dont remember exactly how much throttle is required but if the car doesnt know exactly where its positioned it wont engage for safety of the motor. </TD></TR></TABLE>
I thought the throttle position was determined to be adequate based on manifold pressure. Would the TPS matter in that case?
nkcalvert09
06-11-2011 10:43 PM
TurboCoop
09-16-2005 12:52 PM
