Best cam/ignition timing on a D16Z6
I have a 94 EJ and I was wondering what would be the best cam/ignition timing mix for an all-motor D16? btw searched an nothing, also I have the basic I/H/E
Re: Best cam/ignition timing on a D16Z6 (B16EJ1EG6)
If all you have is I/H/E, I'm going to say OEM cam and ignition timing.
There is no "best" cam or ignition timing for all engines. You'll have to put it on a dyno to see.
i had a stock p28 cam advanced 2 degrees with 40 psi of fuel, probably not the smartest but it pulled hard as hell from 45 in a 93 cx hatchback
advance it and try a few runs and see how it runs? my z6 pulled gsr's and si civic's
but it was fully gutted
Re: Best cam/ignition timing on a D16Z6 (nicks-eg6)
Its funny cause a year ago i did a Z6 with y8 head and 2 degrees advanced with about 45psi fuel and i was so amazed how it pulled in a 93 eg. it was crazy.
Re: (B16EJ1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16EJ1EG6 »</TD></TR><TR><TD CLASS="quote">HAHA ROFL what about ignition?</TD></TR></TABLE>
lol i used stock ignition.... your motor would be revatively stock so you really don't need to upgrade it
Re: (B16EJ1EG6)
If you change the cam timing it will hurt you in some areas of the RPM band and help you in others, MAYBE. Maybe it will help you above 8000 RPM.
Either way if it helps you or hurts you, when you drive the car you're going to think it did you wonders. Just like all these people posting in your thread. Put it on a dyno and you might be inclined to put it back to stock.
Ignition timing: usually it's a safe bet to advance it to the high side of spec, which on a Honda is usually 18 degrees. There's a nice little mark there to help you out. I had a JDM D16 though that did not like anything other than 16 degrees and exactly 16 degrees unless I ran 91, and even then, the power with 91 and 18 degrees was the same as 87 and 16 degrees.
And yes, I had a friend that worked at a dyno shop and could stay after hours.
So just finished tune with 2 degrees advance and 16 degrees BTDC. Results where better than expected 'cause it pulled hard later today, I'm going to race my friends stock full interior B18C EG.
iphatcrxi
15
11-15-2006 04:21 PM
SOHC_MShue
26
02-04-2004 04:59 AM
low-tech assassin
11-03-2003 06:50 PM
fastcrxsi90
06-20-2003 09:05 PM
