GSR with cable tranny... putting in hydro tranny.. need some help
I have a GSR motor right now i am putting a hydro tranny on it. It came with a cable tranny. Will i need to change the clutch and flywheel as well?? thanks
Re: GSR with cable tranny... putting in hydro tranny.. need some help (Ep1dem1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep1dem1c »</TD></TR><TR><TD CLASS="quote">I have a GSR motor right now i am putting a hydro tranny on it. It came with a cable tranny. Will i need to change the clutch and flywheel as well?? thanks</TD></TR></TABLE>
I know for a fact D-series Cable/Hydro transmissions use different clutches/pp/flywheels, I'd imagine B-series are the same way.
Re: GSR with cable tranny... putting in hydro tranny.. need some help (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">
I know for a fact D-series Cable/Hydro transmissions use different clutches/pp/flywheels, I'd imagine B-series are the same way.</TD></TR></TABLE>
They use the same flywheels no matter if its cable or hydro... so you don't know for a fact. And some cable d-series use the same clutch as a hydro it just depends on the year. It depends on the splines if you need a new clutch or not. If it's a big spline cable tranny then you don't need a new clutch. But if it's small spline you will. Usually YS1's and Y1's are big spline. What's the tranny code?
