Low Oil Pressure on Startup???
Recently i put a new motor in my car...D15b7 and kept my D16z6 Head (Mini Me Swap) i did an oil change on the motor 5w-30 Castrol Full Synthetic. Oil level is a little over the full mark but im told it wont harm it.
Anyways i start the car and the Oil Pressure light Stays Lit for a second longer that it should then turns off every time...It also seems like the engine has to build up when i start it...This Whole Process Take Maybe 2 seconds but its Noticable
After all of that the engine runs Perfectly fine...No Oil Lights or Power loss..
What could be the cause of this and what could possibly fix it?
Re: Low Oil Pressure on Startup??? (-JSpecEk*9-)
eh i dont know i just like to try to catch things early...ive never had that problem nor drove a car where that happens...anybody else?
* B A N N E D *
Re: (sireg6)
I jsut did a gsr swap in my ek.. It wasnt on before but then after driving around I noticed wierd idling and the oil pressure light comes on.. I also loose a lil power like its about to shut off... After seeing this I quickly shut off the engine to prevent any damage.. I wonder what could be the problem.. anyone know the answer???
BUMP!
BUMP!
* B A N N E D *
Re: Low Oil Pressure on Startup??? (sireg6)
U jsut did a swap right??? check your wiring again!!! my light was on and turns out that I didnt have one of the wires hooked up.. it wasnt a sensor but one of those plug in pin wires.. double check your work make sure no wire is loose
Re: Low Oil Pressure on Startup??? (562daybid)
haha good thought but the light turns on but still turns off...and you can clearly tell somethings a miss when it starts...thanks tho
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sireg6 »</TD></TR><TR><TD CLASS="quote">haha good thought but the light turns on but still turns off...and you can clearly tell somethings a miss when it starts...thanks tho </TD></TR></TABLE>
you may have a knock then.. does it sound like marbles are moving around in your engine when you start the car for a few seconds?? if so then you need to change your oil pump or do some serious rebuilding
nah no knocks... thats the funny thing...runs pretty much perfect. I actually recently pulled my last motor for a knock and now it runs fine...just that lil startup issue.. Idk maybe im just trippin. People who hear it say im overreacting...Guess it just a driver knows his car..oh well
eg6madness
09-26-2008 02:32 PM
xlasianizelx
05-01-2008 07:42 AM
