Check engine light on, but no codes showing
Here's a quick overview of my problem:
Stock D15B7, ran good with no CEL. Swapped into another car, when you start the car it sputters for 3-4 seconds and then the CEL comes on. After that it runs & drives OK, but still has a miss at idle both cold & warm.
When I jump the 2-pin connector and turn the key on to check codes, the CEL stays solid and doesn't shows any codes.
Here's what I've checked/changed:
* Distributor
* ECU
* Plugs & wires
* Checked grounds
* Checked vacuum lines
* Changed timing belt when motor was pulled (triple-checked to make sure it wasn't one-tooth off)
I'm just about stumped for ideas, so any suggestions would be appreciated
-Dustin
* Distributor
* ECU
* Plugs & wires
* Checked grounds
-Dustin
jlsmi2
19
01-15-2016 08:37 AM
clash
06-28-2005 11:50 AM
