Burning oil? Help
Burning oil? Help
So I have been noticing that every oild change, which I do myself, I haveabout a quart of oil after 2500 miles of driving. I fill it with just over 3 quarts and use the dipstick to check the level needed. This last time I let it go to 4000 miles cause I was busy and the oil light started to flicker. I checked the levels and the stick showed empty. A TINY bit of oil on one of the corners of the stick, but that's it. I changed my oil and no oil lihgt problem anymore, but obviously I still have a oil loss problem. My car seems to run fine and I never notice any smoke coming out the back. I have changed the oil filter with the oil every time. I use Mobil 1 5w30 and saw somewhere that this oil is known to burn. Is it burning slowly enough for me not to see it or could this be a different problem? The only other thing I am doing to my car is adding FP60 oil additive and when I can FP60 fuel additive to clean things out and keep them clean. Any thoughts are appreciated. What should I check and should I change oil? Thanks
Steve
Steve
Re: Burning oil? Help (stevanrk)
Well First thing you should be looking for is Blue smoke out the exhaust. If not next would be a compression test if that seems normal than a leakdown test to see if your valve stem seals are fried. when you change your oil does it come out looking black as hell?
HT White Ops
CaSITE Motor Honey Oil Stabilizer, aka Gorilla Snot, is your friend!
http://www.casite.com/product....tID=1
If you're a cheapskate...
