auto/manuel axle question help
I have a 92 ex abs auto trans with bad d/p axles. My donor axles are from an 95 ex manuel trans non abs. My question is can I run non abs axles on my car and is there any difference between auto/manuel axles? Stock motor stock trans. Thanks
Seagull Management
Re: auto/manuel axle question help (homedefense78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homedefense78 »</TD></TR><TR><TD CLASS="quote">I have a 92 ex abs auto trans with bad d/p axles. My donor axles are from an 95 ex manuel trans non abs. My question is can I run non abs axles on my car and is there any difference between auto/manuel axles? Stock motor stock trans. Thanks </TD></TR></TABLE>
Theres no difference between automatic and manual D-series axles, ABS and non-ABS are different though, you can use the non-ABS axles but you will loose the ABS, or you might be able to take the ABS ring from the old axles and press them onto the new axles.
Re: auto/manuel axle question help (94EG8)
Thanks I can care less for abs, fitment was my concern. I suppose there's no way to get rid of the abs light then?
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homedefense78 »</TD></TR><TR><TD CLASS="quote">Thanks I can care less for abs, fitment was my concern. I suppose there's no way to get rid of the abs light then?</TD></TR></TABLE>
Pull the bulb from the cluster, honestly i'd try just pressing the old ABS rings onto the new axles first. ironically enough i'm running automatic ABS axles in my 5 speed non-ABS LX btw.
lucas569
09-29-2001 06:20 PM
