cam holders .... help pls
as some one got a pic of the cam holders in place ,so i can see what order they go in with the numbers and wich way the center one goes.
ive bought a head but it come in bits .
ive done lots of searching but cant find nothing.
thanks
thanks
Re: cam holders .... help pls (mcvtec)
im pretty sure that on a ls the arrows for the cam holders pointed towards the distributor.
idk on any other motors. i can check on my d16z6 for you if you have a SOHC.
Re: cam holders .... help pls (pleej)
Ok listen carefully ok....
so this is you looking down at your head...
NOTE: They are numbered with arrows point to the dizzy on the center of the cap. just clean the caps and you'll see
I don't remember what number is stamped on the two I left blank but they only go on one way so you can mix them up. Next time you do this buy a marker and label them for reference later. If you need more help Pm me.
Thanks
Thanks
