will this prop valve work?
like the title says i'm removing my abs and need to know if this prop valve will work
http://cgi.ebay.com/ebaymotors...ZWD1V
Seagull Management
Re: will this prop valve work? (messeduprex)
Someone correct me if i'm wrong, but aren't all the lines pretty much completely differnet on ABS and non-ABS civics, your going to have to either cut and splice lines, or ideally just get the hardlines off a DX sedan. as they are now I don't believe any prop valve will work. what you want for a prop valve is the '94 - '01 RS i believe, 4 wheel disc integra, no ABS.
Re: will this prop valve work? (94EG8)
i'm going to run custom hard lines from the mc to the pro valve and from prop valve to the front
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex »</TD></TR><TR><TD CLASS="quote">i'm going to run custom hard lines from the mc to the pro valve and from prop valve to the front</TD></TR></TABLE>
Ahh, in that case i think you'll be ok with the EK prop valve then.
98silverhatch
09-27-2002 02:26 PM
