Stuck Axle Nut on a Honda Del Sol '93
The Front Driver side axle nut is frozen. I've even tried a 3 foot cheater bar when trying to loosen it. Is there something I'm missing? Any suggestions?
Re: Stuck Axle Nut on a Honda Del Sol '93 (jh08558)
in had the same problem on my ek with that dam axle nut..what i did was that i cut the nut off the top but then again i did not need my axle..you could use a drill bit or a dremel with a metal cutting piece..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh08558 »</TD></TR><TR><TD CLASS="quote">The Front Driver side axle nut is frozen. I've even tried a 3 foot cheater bar when trying to loosen it. Is there something I'm missing? Any suggestions?</TD></TR></TABLE>
did you de-stake the nut?
Re: Stuck Axle Nut on a Honda Del Sol '93 (messeduprex)
if a 3ft. cheeter bar dont work use AIR
my buddie broke like 4 breaker bars on an axle nut, we brought over an impact and had no problem
did you unbend the notch? i've had problems with them too, and i used a impact off an 8gal 7hp(?) compressor.
i ended up using a torch to heat it up, then using a 3/4inch breaker bar with another 3 foot pole on that.
it was a f**king *****.
Re: Stuck Axle Nut on a Honda Del Sol '93 (Pothole987)
i personally just stand on the breaker bar and bounce up and down on it. and always lossen the axle nut with the tires on and on the ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex »</TD></TR><TR><TD CLASS="quote">i personally just stand on the breaker bar and bounce up and down on it. and always lossen the axle nut with the tires on and on the ground</TD></TR></TABLE>
LOL, I did this with a 4 ft extension on my friend's car. Snapped the drive on the breaker bar.
Re: Stuck Axle Nut on a Honda Del Sol '93 (jdmdikk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdikk »</TD></TR><TR><TD CLASS="quote">i snapped 2 or 3 breaker bars on my ek..lol..just cut the nut if you dont need or heat it up.. </TD></TR></TABLE>
Just buy a quality air gun and you dont have these dumb problems
gsrcivic619
10
01-05-2004 04:07 PM
