Question: My car is idling up and down. What can be the problem???
Well when i start the car. It idles up and down from 3000 rpm to 1000 rpm. Someone told me that it does that cause i need a new intake manifold cause its clogged . Is that right?
Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">idle air control valve , its on the back of your intake manifold .
Yup try that or it could just be a vacuum leak or a hose that has come off
Re: (hibbarD16z6)
my friends honda accord had this problem.
he changed the intake maifold and BAM!
the problem went away.
he also said that at 1st he changed the spark plug wires and it went away but came back again a week later.
so his neighbor told him to change his intake manifold and its been gone since then
i can also be your FITV....Fast Idle thermal valve, clean that out too as well as the Idle Air control valve. Here is how to clean the FITV....
https://honda-tech.com/zerothread?id=1564019
Grab some throttle body cleaner and spray it on ur Intake Manifold gasket all around and see if it changes the RPM when spraying...if it does....Need a new gasket...and while ur at it..clean the manifold from the inside...
Re: Question: My car is idling up and down. What can be the problem??? (aeenox)
last thing to add i had an accord as well 90 when i redid the clutch with a light weight fly and lightened clutch it threw it off as the obd-0 didnt know how to adjust the cold idle to acount for it... just a side note...
Well i cleaned the IACV, and i still have the same problem. I cleaned out the gaskets and the cover. So should i go for the FITV now?
90% of the time, this is a vaccum leak.
if you've changed anything or worked on anything in this area, check that first.
otherwise, you can run the engine, let it idle and spray carb cleaner or break parst cleaner strategically around the manifold and related parts listening for a change in the idle (it may smooth out slightly or rev up some more)
this will get you in the neighborhood of your leak
Re: (mattyv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattyv »</TD></TR><TR><TD CLASS="quote">take off your fitv screw the plastic piece inside down. problem solved ill put 5 on it -.-</TD></TR></TABLE>
So are u saying to bust this?
Cause tomorrow before i went to work i was gonna clean out the fitv. But 1st imma spay the brake cleaner around the intake manifold
probably tps, skunk sells one now for like 20 bucks on ebay.
http://www.team-integra.net/fo...Topic
thats very helpful as well.
Disassemble de IACV completely. There is a piece inside the IACV that oscillates and gets stuck with dirt. Just clean it up.
Re: Question: My car is idling up and down. What can be the problem??? (javierasous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by javierasous »</TD></TR><TR><TD CLASS="quote">Disassemble de IACV completely. There is a piece inside the IACV that oscillates and gets stuck with dirt. Just clean it up.</TD></TR></TABLE>
How do u take apart completely cause i was trying to but i couldnt.
cover your hand over the throttle body with the car running. it's gonna suck your hand really hard. if the car does not die, it's a vacuum leak.
well i cover the throttle body and the car shut down. So i dont have a vacuum leak. So i guess imma just buy a new intake manifold. Would a d16y8 manifold fit a d16z6?
Re: (aeenox)
u dont need to buy a whole ne intake manifold. its gota be something little. how long has it been doin that. also u might want to check ur idle screw.
and yea a d16y8 manifold will fit. how much r u gona get it for. b/c i will be better for ur z6.
i threw a y8 manifold and a GSR throttlebody on my car... and its a big improvement.
Well my friend totaled his 99 civic so imma get it from his car...he will prob sell it to me complete for like $30. Wats a better engine a d16z6 or a d16y8? cause i was also thinkin of buying his engine to built a bit. The car was idling like that when i bought it which was like 1 month ago. but i have been driving it for 2 weeks
Re: (aeenox)
if you have an FITV under your throttle body, then use the procedure that was posted above.
a lot of the time this is the cuprit. but this is only a temporary fix though. honda doesn't recommend tamporing with it, only to replace with a new fitv set to factory settings. it's around $50
