idling issue
Re: idling issue (HondaGuy951)
why the hell would you need more info...either its the IACV(which was mentioned), possible vacuum leaks(like was mentioned also, ot the TPS...those are usually the culprits and if not than its usually an ecu problem...so any wire harness, intake mani, model, make, year their all pretty irrelevant to the problem
Re: idling issue (vtecb18c)
i used the stock d15b7 wiring harness that came on the car.. previous owner decided not to put any oil in the engine so it seazed up. does anybody have the firing order for d15b7?
Re: idling issue (one-cam)
it may be the ignitor in the dizzy......or the coil....theres somethin wrong with the distributor you just have to troubleshoot now...i think the idle fluctuation might have been bad timing all along so i would replace the dizzy or its internals...just my opinion
