92 to 95 civic A/C parts fit a del sol?
I am thinking about purchasing a 95 Del Sol without A/C The question is will a full a/c kit from a 92 to 95 civic fit? are the lines the exact same?
I searched and could not find any definitive answers as most topics were a/c delete
Modified by crxstylin at 8:52 AM 9/12/2008
Re: 92 to 95 civic A/C parts fit a del sol? (crxstylin)
best bet would be to check like http://slhondaparts.com
try to match the part numbers.
im sure the compressor, condensor, and drier are all the same.. not positive on the lines
The 92-95 A/C parts should work, the civic del sol and the base model civic coupe are all the same chassis i believe.
Re: 92 to 95 civic A/C parts fit a del sol? (-PaulMc-)
turns out i thought the car had ac but never did. whats the name of the thing where the high and low side ac lines connect to at the firewall. I am guessing its the evaporator
Most of the hard components are the same, but the lines are slightly different; to what extent, I'm not sure, you'd have to compare them side-by-side. The del-sol's came with the r134a system, so if you can get the lines for your car from another del-sol, you can get the other components from other 94-95 civics (the 92-93 ones used the old r12 systems so they won't fit with your lines).
And yes, the box underneath your dash is called the evaporator.
hotwheels88
04-09-2007 08:50 PM
Dark knight 330
36
07-12-2004 09:15 PM
