lca, camber kit
lca, camber kit
i just swapped out my rear drums for some 97 integra gsr disc brakes on my 95 civic ex. my question is what do i buy my lca's for? and what do i buy my camber kit for? thanks!
Modified by 93dagsr at 1:12 PM 8/28/2008
Re: lca, camber kit (93dagsr)
The LCAs are for looks (if its aftermarket) and to add a rear sway bar. (stock ones to add a sway bar)
A camber kit would be to have a higher or lower camber rate on your alignment.
so... stock lca's? i knew what they were for i know that they're mainly for looks. i just wanted to know what to ordr them for???
thanks a camber kit for the 95 civic will fit then?
oops meant to put that the car is a 95 civic ex
Re: (geebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs »</TD></TR><TR><TD CLASS="quote">get lca's and camber kit for your 95 civic ex.</TD></TR></TABLE>
civic.... integra.... lca's are close enough, if not they are the same, buy either one. The stock integra allows bolts for a sway bar or whatever its called. Camber kit is the same too i think, But I would get the integra one just to be on the safe side. Rear camber can be adjusted with washers=] if you wanna save money. You also need longer bolts as well.
