5 lug conversion problem
Old 08-30-2008, 10:33 AM
bmxer's Avatar
Default 5 lug conversion problem
im doing a 5 lug conversion for a 93 civic coupe with a ls-v-tec. I have the jdm itr 5 lug with the 36mm axle nut. The driver side fit perfect, but the passenger side axle seems too long, and the hub assembly wont fit into the upper a-arm. is it supposed to fit? or am i supposed to get a different axle?
Old 08-30-2008, 11:09 AM
Hanmin's Avatar
maybe you dont got the axle all the way in on the tranny side?
Old 08-30-2008, 11:25 AM
Kendall's Avatar
Also note that it's particularly easy to pull the axle shaft out of the CV joint with the boot still on. There are bearings in there that need to be lined up correctly or the shaft won't slide back in.
Old 08-30-2008, 12:37 PM
nipcup101's Avatar
Default Re: (Kendall)
the shaft of the jdm axles just looks to long fit perfect on my 97 gsr but not my 95 ex coupe dont know why this is gay HELP
Old 08-30-2008, 12:43 PM
I am my avatar
naRIPSTA's Avatar
Should've just gotten the 5 lug adapter plates
Nah just kidding lol
Old 08-30-2008, 12:53 PM
bmxer's Avatar
Default Re: (nipcup101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nipcup101 &raquo;</TD></TR><TR><TD CLASS="quote">the shaft of the jdm axles just looks to long fit perfect on my 97 gsr but not my 95 ex coupe dont know why this is gay HELP </TD></TR></TABLE>
I took the 5 lug off of a gsr and put them on the coupe. it fit the gsr, but i have no idea why its not fitting the coupe. with both axles next to each other, the JDM shaft is 1-2" longer than the stock one.
Old 08-31-2008, 11:35 AM
nipcup101's Avatar
Default Re: (bmxer)
up top
obviousBOY
Suspension & Brakes
03-30-2016 12:27 PM
vu337
04-27-2009 04:40 PM
supermonkey
Transmission & Drivetrain
09-27-2008 11:18 AM
samnizzle
Honda Civic (2001 - 2005)
17
07-27-2008 07:43 PM
silentdeath12886
02-11-2006 07:59 AM
Quick Reply: 5 lug conversion problem
