accord ex injectors into a b16?
i was told by a friend of mines to place 94+accord ex injectors into my 00 b16 motor..he said that i will have increased power..is this true,or has anyone done this before??
Re: accord ex injectors into a b16? (jdmdikk)
do you have a fuel regulator? are you putting more pressure through your fuel line? and, are the accord injectors bigger (higher flow) than the SI's? (which i doubt) unless you upgrade your fuel delivery then higher flow injectors (any) won't do a thing... if you want higher flow injectors that are not all crazy or expensive... you should get gsr or type-r injectors.
Re: accord ex injectors into a b16? (unsungfate)
i was told that it has way better flow and that i would need it with the injector plugs..i do plan on putting a fuel pressure regulator for more gas flow
is your motor stock?
Prelude injectors are best imo, i dont know what cc the accourd injects are.
1992-96 Prelude VTEC peak n holds
1997-up Prelude VTEC saturated
why do you want more fuel?
