Cant get crank gear off help!!
Ive tried to pry it from both sides and it wont budge. I even broke 1 of the ears off on the spacer part by accident. Shouldnt it just slide off without any issues? Any help is appreciated. Pic of the gear is below
Yeah I guess I could try some liquid wrench on it then try to pry slowly. Ive tried a pry bar on each side and it still wouldnt budge. Hopefullt the liquid wrench will do the job
yes there is a key way, its supposed to b there just like the key way on the crank pulley. That gear should slide off there but for some reason its stuck. The block does have some surface rust from bein outside. Its getting hot tanked as soon as I can get that gear off so I can get the crank out
Ive tried PB blaster and still nothing, but it has moved a lil, I guess ill just keep spraying and keep wiggling with the 2 prybars until it comes off
BigPlansNoMoney
09-25-2007 12:53 PM
